how set default encoding of sending e-mails?
My default encoding is Windows 1250, I woud like to have ISO standard, 8859-2, but I must change it everyone, when I write new message. How set ISO to be default encoding of my mails - language is polish
From what I was able to find out right here
(I use 1.60 at work - thank god, a bugfree version!)
there isn't much you can do. I guess it's a bit diff.
in the v3.5, but it might be worth a shot.
When you recieve a msg, right click the body of the message, and go to 'character set -> ISO-8859-2'.
Then click 'set as default'.
With a little luck, it will set it as default even
when you send out messages, not just recieve.
Account -> Properties -> Templates -> New message -> Use Character set -> Central European (ISO-8859-2)
it works for me ...
regards
Marcin
LOL!
That should really work :)
I never used it totally missed that setting ;)
And it was *SO* obvious :)
Thanks Marcin, I might set it to ISO-8859-2, too... :)
