Save layout
Using "Workspace -> Windows split mode" I've set my ideal layout.
It turns out difficult to keep it permanently saved.
Sometimes it survives restarting the Bat!, but quite often it reverts to the factory settings.
Any solution for this?
Have you tried running The Bat with Admin privileges, making the desired changes and saving them? That's what I'd try (to launch a program with Admin rights, right-click on its shortcut and choose 'Run as Admin' (or similar words)).
Trying admin mode.
Do the settings need to be saved? Guess so, otherwise you wouldn't mention it :-)
Where is save settings for the layout/workspace located?
Sorry -- you don't have to actually 'save' them, they will (or should) be saved on exit of the program.
I tried starting in admin mode, setting the layout and exiting. Unfortunately that doesn't help.
Well, maybe this is one of those things that fix themselves when doing a Windows reinstall.
There is no layout saving in TheBat. Sad, but true. Ask support about this feature request.
