Copy/paste doesn't work in View Message Source window
Since I installed 3.5, I'm unable to copy the contents of a message including the headers in the View Source Message (F9) windows either by CTRL-C or Edit | Copy - the 'Copy' function is greyed in this window.
I can work around it by saving the message and then copy the contents of the saved message, of course.
:cry:
Any thoughts ?
IIRC that was corrected with the 3.5.25 release.
I believe you could avoid it by clicking somewhere in the source screen before trying to select/copy the text.
Clicking in the source screen doesn't help in this case, although I should state that the problem only occurs when selecting *all* text (using CTRL-A or simply by selecting all the lines).
Simply copying words or lines from the source screen poses no problems.
