Quick Search - possible product enhancement.
1. I use the quick search box a lot for quickly filtering messages. It would be really good to be able to include some simple Boolean operators in the search such as : Jerry && computer && disk (Boolean operator could be anything) . I realise this can be done in the main search window but it would be nice to have it in the quick search.
2. As it is, the above search will result in three new tabs at the bottom of the screen. These can mount up numerically very quickly and is a pain to remove singly. Could we have a right click on the tabs which allows you to delete all tabs except the All, Unread, Information Tabs?
Thanks
Hi Jerry, great suggestions, but as this is mostly a user-to-user forum, you may want to submit your ideas to Ritlabs' developers through the Support option above.
Ah - I hadn't realised that. Thank you.
I reported this as a product suggestion and am very pleased to say that they have implemented it. You can now type jerry+computer+disk in the quick search box and if you right click on the search tabs at the bottom you can close them all down at once.
It's lovely to think that the users can have an influence on the product's development.
