Preferences storage location, options > preferences
Where are Options | Preferences stored? For instance, where can I find the Message List font and font size? In the registry? In the program folder?
TIA for your help.
regards, AndyA
I don't know, but it shouldn't be hard to figure out.
If it's in a file in your Mail directory, its date/time will correspond to the moment when you changed the font setting and closed The Bat.
If it's in the registry, you can export HKEY_Current_User\Software\RIT\The Bat! to a .reg file, both before and after you change the setting and exit The Bat, and then compare the 'before' and 'after' .reg files.
I haven't looked in the registry, but a lot seems to be stored inside files in the mail directory. Some with the extension .CFG are binary, others with extension .INI are textual.
Using Daniel's method I was able to figure out that the Message List font information is stored in the file COLORS.INI.
