SessionUnknownContentType ct (50) and SessionUnknownContentType ct (53)
My provider supports TLS, but I can't get it to work with TB.
The account logs says :
Code
!27.07.2022, 14:58:25: SEND  - TLS protocol error: Unexpected message SessionUnknownContentType ct (53).
!27.07.2022, 14:58:36: SEND  - TLS protocol error: Unexpected message SessionUnknownContentType ct (50).
Unfortunatly, the 'real' SMTP-log remains empty. (It is not totally empty,
but it seems only to log successfull (non-TLS) sendings).
What can I do to fix this problem ?
(I'm using TB version 10.1 - Professional Edition)
Solution from this is not solving this issue:
https://www.ritlabs.com/en/forums/forum4/topic9674/
Edited: True Friend - 27 July 2022 16:16:01
Why did you literally copy that 12 year old message?
Have you asked your provider which settings you should use? Or are you experimenting with a mail server of your own, like in your other message?
What are your settings under Account | Properties | Transport | (Send Mail section) ?
I have this problem with gmail
!17/09/2022, 09:55:31: SEND  - TLS protocol error: Unexpected message SessionUnknownContentType ct (50).
