Filter question, how to set up a user defined condition
I belong to several email groups and normally when I reply to any message it goes to the whole group but recently it is only going to the individual sender.  I would like to set up a filter to have the default for that one group be "reply all" but that is not a condition is in the option list.  How do I set up a user defined condition?
Thank you,
Ann
You'll probably want to change the Reply template, instead of trying to solve this through a filter (if that's even possible).
First you'll have to find out what is going wrong, though. Has something changed in the mailing list software or method that this group is using? Is the address to which you want to direct your reply contained in the Sender header field of the message, or in the Reply-To header field? Do the messages from this group all arrive in one particular folder in your account tree in The Bat?
I really think it is something with the way the group is now handling the messages.  I'll check into that more.  Thank you.
Ann
