Hi all
Im using the bat v10.2. I dont receive emails randomly due to this issue. if there is any new message comming it is not display. bat try to save it to temp folder but i get this error:
>01/10/2022, 18:21:44: FETCH - Certificado S/N: B8BA85B92520A9880A783D58BB2AC300, algoritmo: RSA (2048 bits), emitido de 12/09/2022 8:18:55 para 05/12/2022 8:18:54, para la(s) máquina(s) 1: pop.gmail.com.
>01/10/2022, 18:21:44: FETCH - Propietario: "pop.gmail.com".
>01/10/2022, 18:21:44: FETCH - Emisor: "US", "Google Trust Services LLC", "GTS CA 1C3". Válido desde 13/08/2020 0:00:42 a 30/09/2027 0:00:42.
>01/10/2022, 18:21:44: FETCH - Emisor: "US", "Google Trust Services LLC", "GTS Root R1". Válido desde 19/06/2020 0:00:42 a 28/01/2028 0:00:42.
>01/10/2022, 18:21:44: FETCH - Raíz: "BE", "GlobalSign nv-sa", "Root CA", "GlobalSign Root CA" Válido desde 01/09/1998 12:00:00 a 28/01/2028 12:00:00.
!01/10/2022, 18:21:49: FETCH - No se puede guardar mensaje (Nombre de archivo - d:\temp\batBA72.tmp)
I tried to change temp folder to any other drive but i get the same error. I tried unninstalling antivirus and it didnt solve it
50% it works 50% not
Can you help me?
Can you help me?
