Quote |
Mark Liquorman wrote: After upgrading to 10.5, each time I close TheBat I find an instance of it under "Background Process" when looking in Task Manager. It has a very high CPU usage and Power Usage. Each time I close TheBat after that, another such instance is created! Pretty soon, they are using 100% of my CPU!
I reverted to 10.4 and problem went away. Just downloaded new v10.5.1 and there it is again.
Anyone else having this problem?
32-bit version of TheBat, Windows 10 Pro (64-bit), 16MB memory. |
Are you showing application error logs in Event Viewer? Event Viewer/Windows Logs/Application. I get on closing the following.
Faulting application name: TheBat32.exe, version: 10.5.1.0, time stamp: 0x652ea12c
Faulting module name: TheBat32.exe, version: 10.5.1.0, time stamp: 0x652ea12c
Exception code: 0xc0000005
Fault offset: 0x0000a4e2
Faulting process id: 0x2c80
Faulting application start time: 0x01da01e7541c0ee1
Faulting application path: C:\Users\dfitz\AppData\Local\The Bat!\Main\10.5.1.0\32\TheBat32.exe
Faulting module path: C:\Users\dfitz\AppData\Local\The Bat!\Main\10.5.1.0\32\TheBat32.exe
Report Id: 5c5cb2b5-b5b8-4d35-9613-e80ca9338ddd
Faulting package full name:
Faulting package-relative application ID:
The above has been sent to support.
With 10.5.1 Task Manager now shows 4 background instances of theBat!, not the dozen or so with 10.5.0. So far I'm not seeing 100% CPU usage.
