Is anyone else having problems with The Bat not closing properly and when you restart it, you need to go into task manager and end all references in order for it to start up again? I have the latest updates and it's still doing it. (11.0.3) 64 bit
It's random for me. I've not seen it lately. I opened a ticket recently about that, they acknowledged the issue and said it would be resolved soon. So it still might be in their queue.
How recent was that? v10.5.2.1 of last Oct. 31 fixed a similar problem: "Issue that caused a helper process to remain in memory after exiting The Bat!, preventing the program from shutting down properly, was fixed" If your discussion with Ritlabs' support staff was from before that time, I'd encourage Brenda to report the issue to them using the Support menu near the top of this page. Maybe the same old problem has returned in the current version.
The what's new for v11.0.3 (could have also been present for 11.0.2) states: "Fix some possible sources of AV errors (including ones when switching editor type)". Maybe that took care of the problems for you. |
