| Quote |
Frederick Smith wrote: Is it possible to install the same version over the existing installation? I want to do this while preserving accounts, folders, email, etc. |
Yes, I do it all the time. Everything is preserved.
| Quote |
Frederick Smith wrote: It's a long story. I can't use TheBat64.exe. It crashes. And, yes, I checked folders by hand to see if TBLauncher64 was there. I was waiting for the latest version of Windows 11 24H2 which would fix a lot of problems. |
I'm using Windows 10 without any crashes or similar problems, so can't help you there.
| Quote |
Frederick Smith wrote: But, I can't backup everything in TB unless it's by hand. |
I do backups by hand anyway, since I find it simpler and faster. I just copy over everything from TB's Mail Directory (Options -> Preferences -> System).
