Hi.
I've been a user since TheBat v9. My problem is, I press "F2" to load the list of new messages. They appear. But when I select a message, most of the time, the message does not load. Nothing happens.
I click on another message, sometimes nothing happens, sometimes that message loads and I can read it. Then I go back to the previous one which was not loading and then it loads and I can open and read it.
When v10 was out, I waited 1 year to be sure most bugs were ironed out and then upgraded to it.
But the same behaviour remained.
So YES I can select and read ALL my messages.
BUT each time, some messages are not loaded. Nothing happens when I select messages in the list. I must select 1, 2, 3 before the message I select can be loaded and read.
Sometimes at first attempt, the message loads up immediately. But most of the time not.
This happens either when I start the program, or even when the program is opened, and a few hours later I click on it in my taskbar, then press "F2", then:
- I select a message, it does not load. So I have to select another message, 1, 2 or 3 times in a row to be able to load one, then others usually open normally
or
- I select a message and it loads and I can read it.
Am I the only one experiencing that? Either Windows 10 or 11, same behaviour.
Is this something known?
TheBat is the only client doing that to me. Since the first day I tried TheBat, I experienced that. It has been a long time I wanted to talk about that, but postponed it and tonight, I write.
I will not upgrade to TheBat 11 to try to see if it is better. That is not an option.
Thank you for any help.
or
