Dear The Bat! Users!
I use The Bat! v.11.5.2 64-bit.
When I try to copy a fragment of an HTML message and paste it into another program, such as MS Word, the text is copied correctly, but the images are not. Instead of each image, an empty frame appears.
Has anyone encountered this behavior? Is there any way to change it in the settings?
Thank you in advance for any advice,
Łukasz
Zamiast każdego obrazu pojawia się pusta ramka.
Edited: - 17 April 2026 10:54:24
