outlook.com IMAP connection issue
Using v 12.1
Connecting to https://login.microsoftonline.com/common/oauth2/v2.0
Some providers have disabled the OAUTH mechanisms for built-in browsers  for security reason. While we believe our browser is 100% safe, you  might need to use your system browser to get the authorization code.  Once you obtain the code, copy and past it into the input field below
But I get https://login.microsoftonline.com/common/wrongplace
This is not the right page
You have reached the wrong page. Please close this app or window and try again.
Edited: Niamh Holding - 19 April 2026 17:55:48
Screenshot
I've done OAUTH in TB only once a couple of years ago, and that was for GMail. I don't remember seeing this window. Nevertheless, it seems that the built-in Chromium browser in TB will not work here. Try clicking on "Open in system browser" and pasting the code you get there into the field at the bottom. If that does not work and your system browser is not Microsoft Edge, set Edge to be your default browser and try again.
