In an IMAP account, when playing of a distinctive sound is chosen as a filter action, the sound is repeated for each IMAP message in a folder as the folder is synchronized. For a folder containing 2000 messages, this is highly annoying.
I meant to make the conditions more specific. My guess is that you check for the sender of the message matching some conditions and nothing else.
And I meant to suggest that you check in your filter whether the message is found in the inbox.
I'm just a user of The Bat! I don't work for Ritlabs. |
