Moving deleted messages to Trash not really works
The Bat (IMAP account) should move deleted messages to the "Trash"-folder but it only marks the messages with the deleted flag. In The Bat the Messages are moved but when I use my webmail I see these messages in my inbox.
Why doesn't The Bat move the messages?
I encountered this same problem (and posted it here a week ago) and there's been no response.  It would be helpful to get a response to this problem.
It's possible that there aren't any experienced IMAP users on this forum, that could explain why you don't get any answers on IMAP problems, as this is primarily a user to user support forum.
When TB acts with IMAP analogue to a POP3 account then it's possible that you need to enable 'move to trash' in the account or folder properties.
Why TB doesn't delete the message from the actual folder is easy, that would slow down the mail handling, you'd need to compress the folder on exit.
