Smilies, folder of smilies?
 I just noticed in the programs folder of TB there is a sub folder of images (smilies) how are we supposed to use these smilies in our email when I see no option anywhere to use smilies when creating messages?  :|
Ahhh never mind I found out searching though the forums it's useless to have the smilies since no one else can see them anyway unless they are using TB also.
pitty...what a waste.  :(
Almost every mail client out there now converts text smilies to images. Type ":)" and most users will see a smiling face. Now if you want something more exotic than the 10 images or so that are supported by all email clients, well yes, then you're out of luck & you might as well be using something like Incredimail anyway, if you want to fill your emails with dancing icons :)
