I saved settings from TheBat installed on C-drive.
Then I tried to restore settings into TheBat installed on F:\ drive.
TheBat would start crushing as soon as I'd import the settings.
I had to manually go through all config files and registry settings to discover that configuration which was imported had absulote paths with C:\ drive specified in them! I then had to do "search & replace" in registry's TheBat key (substituting C:\ for F:\) and then change paths in few config files (e.g. smime.ini)
After spending hours on this, TheBat finally works on F:\ drive.
Are TheBat developers aware of this problem?
