quoting empty lines on reply
How can I achieve quoting of empty lines on reply?
Thank you.
I don't understand your question, whenever I reply to a message, the empty lines are in my message too. (Unless I'm deleting them manually.)
What I mean is that blank lines in the original message are not quoted. So, if the original is:
This is the
original message
The quoted version becomes:
> This is the
> original message
Instead of what I want (and what I had in v2):
> This is the
> original message
I haven't been able to find any settings that affect this behavior.
I don't know how you got that in v2. It has always been TB's way to not quote blank lines, since v1 and on into v3. The only way to get blank lines to be quoted is to use the "Paste as quote" function, having copied your quotable text into the keyboard.
iviarck
Thanks, that's good enough I guess.
Yeah, since then the author of the previously mentionand quick template has told me the soltuion for The Bat! v3.x:
In Account|Properties|Tempates|Reply, in the template, the %Quotes should be replaced with %QuoteEmptyLines%Quotes. (It's pretty simple, just it seems to me that the QuoteEmptyLines macro is not mentioned in the help.)
