| Quote |
| You may try exporting from Thunderbird as .csv or tab delimited and then import to The Bat using one of those methods. |
.txt: The correct number of entries are imported, but the fields are all wrong, e.g. the names fields in The Bat are various fields merged, no addresses fields are correctly populated, etc.
.csv: Better, but still does not yield a useable address book due to too many parsing errors.
Perhaps if I struggle with editing the contents of TAB delimited or CSV file long enough, I can get a reasonable facimile of my Thunderbird address book into TB. But, to make matters worse, The Bat does not seem to save the CSV import template for reuse in subsequent import attempts; the prospect of remapping the fields every time is unappealing.
An LDIF import should enable more accurate field parsing ... if I could get it to work.
Can anyone confirm that they have successfully performed an LDIF address book import with version 3.71.03 of The Bat?
