Folder font
Where do I change the font of the folders? I managed to change it once but I have forgotten where the setting is.
Open the Bat,and go to options.Choose preferences,colors groups and fonts,and mix and match. :D
Actually I see no setting to change the folder font. There is a setting for changing the font of the messages but not of the folders. May be I am not looking in the right place?
Options -> Preferences -> System -> Account tree font -> Change
Thanks. That worked. I think I confused Soren, I should have said 'Acount tree font'.
Often the problem with The Bat! is knowing the right name. As soon as you know what it's called you can find it in the settings. ;-)
Hi Kassim...
Yes I was not quiet sure what you meant,but Im glad you solved the problem with Roleofs help.
The Bat is grreat isnt it? :D
When I compare Microsh.ts mail apps against it,its amazing how much better it is.It just takes a lil time to find all the goodies. 8)
