Compressing Folder
TB is only closed on my PC when windows is shutting down (I don't close it manually). But when TB closes in this way, it doesn't perform actions, which it performs, when you close TB manually. e.g. it does not compress the folders, also the checkbox "compress folders on exit" is checked.
Can one solve this problem?
You can set a scedule to purge and compress your folders.
