IMAP settings, Problems Linking to Fastmail
Hello!
I'd like to use The Bat! to access a new Fastmail account I've set up. I'm afraid I'm stumped about The Bat's settings. In particular:
- I have successfully set up the IMAP account and have access to the IMAP folders. Fastmail says I should use my SMTP server for outgoing mail. I'm able to send messages but copies are not stored in the online folder called "Sent items." They are only stored in a folder TB seems to create. I can manually drag these messages from TB's folder to the online folder. How can I get TB to store copies in the correct accounts automatically? (My attempt at doing so using the pre-defined folders" dialog options didn't work.)
- When I check any one of my accounts, the connection center stays "on" as it checks the fastmail account. I can't figure out how to tell TB to stop checking and/or check the account again in a few minutes.
Thank you.
Account menu - Properties - Mail Management - For predefined folders, use these IMAP mailboxes section - Tick the Sent Mail box - Set this to INBOX.Sent Items - OK
Regards
Richard.
