Encrypt message base, Is it possible after installation ?
I reinstalled TheBat! and since I reinstalled the OS too, I had to copy all email folders and tell the program to use them again.
So, all options,accounts, filters and address books have been successfully recovered.
Now I just want to ask you a question, even if I think the answer will be negative....
Now I have thebat! working in "clear" mode, without master password at the startup and without encrypted messages....is it possible to encrypt them now and set a startup master password?
How can I make all my old message base work in encrypted mode? is there any way with thebat! or external utility?
Thanks
Bye
Paolo
Create a full internal backup with The Bat!
And for safety purposes create a one on one copy of your plain text message base.
Uninstall TB
Delete your plain text message base
Install TB again and select that you want to use OTFE
Restore your message base from backup.
Now you should be running OTFE
There is no way to switch to OTFE without uninstalling TB. Or that's not completely true, you could also make the necessary backups, delete your message base and delete this tree from your registry:
HKEY_CURRENT_USER\Software\RIT\The Bat!
Basically this has the same effect as uninstalling and installing TB.
Note that this registry tree has to be deleted manually if you're using TB in a restricted user account under Windows, because the registry settings for TB are user based and Windows doesn't allow uninstall programs to access the registry for other users than the one running the uninstall program.
