Hi there,
I wrote to TheBat! technical support some days ago but I didn't receive any response back yet, so I ask here in this forum even if the question could be kinda OT.
I had a TheBat! 1.62 version that, when I was running off disk space, I simply used the command "compress all folders" and I usually was able to collect some megabytes.
Right now, in TheBat! 3, I can see only two options:
-1- I have to manually compress every single folder;
-2- I have to set the folders to "compress on exit".
IMHO, this is not a good solution and I cannot understand why this precious command has been removed from the UI.
Any hint? I still have only an evaluation version of TheBat! 3 and I'm considering if buying it or not...
Many thanks in advance!
Kindest regards.
Kindest regards.
