Since installing the Christmas edition Mailwasher will no longer maximise The Bat! It wil start the program if it has not been started but if it's running and minimised pressing Process Mail on the Mailwasher screen does not bring it up. It has worked with all the previous versions of The Bat!
I was told that I needed to change the settings so that The Bat! had a icon on the Task Bar which I have done but the problem is still there.
By the way is there an archive of previous versions anywhere?
