Xmas Logo Display
I would like to stop the initial display of the XMAS TheBAT logo at startup!
I understand that one needs to add /NOLOGO to the commandline, which I have done when I have to start TheBat manually... however, how and where do I apply the /NOLOGO when it starts at bootup?
Is TheBat in the "Startup" folder?  If so, just edit the shortcut there!
if NOT, then you need to add it to the registry entry for "TheBat" found either in HKEY_LOCAL_MACHINE | Software | Microsoft | Windows | Current_Version | Run
unless its hiding in:
Hkey_Current_User | Software | Microsoft | Windows | Current_Version | Run
michael walker writes:
Found it here and used a handy little utility to make the change... will see if this works in the morning...
Appreciate the response!!
Al
Al Lawrence writes:
Does not work at boot.. still displays the
useless logo..
I can understand this displaying in a trial version... but after buying it should DISAPPEAR!!!!!!!!!!!!!!!!!!!!
Your short cut should be (In Windows say on the Shortcut bar)
"C:\Program Files\The Bat!\thebat.exe" /NOLOGO
Cheers
MS
Lord Melch writes:
If I click on the desktop icon to start TheBat the xmas logo does NOT display...
It DOES display at BOOT time
VERY annoying as I see no reason to have to see this annoying logo EVER!!!!!!!!! I don't like things shoved in my face after buying the product....
