Connection center visible but ...
Hello,
It is possible to allow the « connection center » but without show it in the task bar?
I use The Bat pro since many years without find this option. I check my emails every 2 minutes and the “connection center” push all the task bar programs on the left each time.
Thank you.
Hello, what if you configure the connection center to be displayed not automatically but always visible, does it in this case push all the task bar programs on the left each time?
Yes, you’re right. The connection center still always in the task bar; even if “The Bat” don’t check the mails box.
A better solution will be a “Splash screen box-like”; maybe on future version?!
