Color messages in Plain text
TB can color messages so you can more easily see who said what. WHere do I find that setting to do that.
Does it just color all quoted text one color, or does it color different responses in different colors?
To use that, do you send messages in plain text windows or in plain text MicroED?
Thanks
Rick
You can set that at:
Options -> Preferences -> Viewer/Editor -> Plain Text/MicroEd
and
Options -> Preferences -> Viewer/Editor -> HTML/Windows Editor
When you're using HTML your contact sees the same as you, when you don't use HTML you define what you're seeing yourself.
Note that there's a difference in what you're seeing yourself when you view plain text with the Rich Text Viewer or with th Plain Text Viewer.
You can set the default viewer for plain text at:
Options -> Preferences -> Viewer/Editor: View plain text messages using
