importing from Windows Mail
Hi everybody,
            I have a computer with Vista Business and an e-mail account on Windows Mail. I want to use The Bat!. I am using an evaluation copy and I plan to purchase the software if I can import the messages.
The only way I found to do that is to export the messages into .eml files and then import them into The Bat!.
It's a long process, because I have many, many inbox sub folders, but if it gets the job done, so be it.
The problem is that this system is not what I need.
When I import the .eml e-mail messages into my The Bat! inbox folder, the received date is not the original one, but it's the date when the import took place. The "created" data is ok, though.
Now I have thousands of messages all received today.
I can't have it that way, I need a way to keep my original received data.
Is there a way to do that?
If only I didn't migrate my account from OE to WM, I would have been able to use the Mailbox Import Wizard, but now I am stuck with Windows Mail because I do not have my old OE message folder.
         Even if I had it, though, I would lose 2 months of messages, and that's something I can't have either.
If I can't find a way to move my messages the way I want, I can't use the bat! for my work e-mail.
I will purchase it nonetheless, because I find it a great e-mail program and I will use for my personal e-mail, but the business account is the one I need the most.
I hope somebody can help me out.
Thank you all, whether you can help me or not.
Sebastiano
I'm not sure but I *think* Windows Mail is just a new version of OE so the mail import assistant of TB! might be able to cope with that.
Or a total different approach would be to use an ISP that offers IMAP. Gmail does that for example (you have to enable imap in the gmail settings).
Make Windows Mail connect to this IMAP server, upload your mail.
When you are done, connect TB! to the IMAP server and download the messages again.
OR if you'd rather not use something like gmail you can set up your own imap server with MacAllen Mail Solutions:
http://macallan.club.fr/MMS/index.html
Going the IMAP way is keeping your sent and received data intact.
Windows Mail is Vista's Outlook Express.
The Import assistant of TB! does not work with it.
I can't change ISP, it's the e-mail account I use for work. And it doesn't use an IMAP server and I can't use an external server (company policies).
There's another way to "export" messages from Windows Mail: Microsoft Excange. I have never used it, but I'll give it a try.
I hope I can figure out a way to switch e-mail program.
Thanks.
Sebastiano
