TB 4.0.14
1. I would like for TB to load with Windows, but not check mail until I check it manually. How do I do that?
2. When there are NO messages, is there a way to change the background color of the global "In" folder in the right pane(From..To..Subject..Received, etc.)?
Also, the tree and Message pane when it is empty?
3. Where can I download TB skins?
Thank you.
Thank you.
