Email issues Vista 64, I can send but not receive.
Just built a new system with Vista 64 bit. Downloaded and installed the latest version of theBat (4.0.14). Restored my email and configured my new accounts (I also changed ISP providers). I am able to send but not receive. I get the following error:
2/24/2008, 11:13:49: FETCH - receiving mail messages
2/24/2008, 11:13:49: FETCH - connected to POP3 server
!2/24/2008, 11:13:52: FETCH - Server reports error. The response is: -ERR Unknown user or incorrect password
I have tried the same account under Outlook and Dreammail and it works fine. I am Beta testing AVG 8 and thought it may be the issue so I un-installed it and there is no change.
I have tried all of the MAil Retrieval settings. I have set it to prompt me for password, I have re-entered all the setting...I even did a cut and paste from Outlook.
I am have not joy at all...anyone offer any help...PLEASE..
Thanx
Harvey
I unloaded ver 4 and reinstalled ver 3. same issue.
Does no one have any input?
If you are really sure you have entered the username and password correctly then:
Double check your connection type, ports and your authentication. It smells like wrong authentication
However you mentioned that you have a new ISP. SOME ISPs don't require NAME but rather [email protected] (or sometimes name+domain.com) as the email user name. Try that first especially if you are using your own domain name hosted somewhere.
OK this is strange I dropped the qualifer and everything works like a charm...However with DreamMail and Outlook I need the fully qualified name.....Any ideas why?
Thanx for the help....
Harvey
And to think I spend hours checking & double checking things......
Glad you got it fixed  :)
