'mail to' links BIG problem
Hi there,
I am currently using The Bat Pro 3.99.3 with Firefox 2.0.0.12 and Windows Vista Home. The problem that gives me a massive headdache is when I try to use the mail to command From firefox I get a Bat "red cross warning message" like: Cannot open file "mailto:?body=http%3A%F%2Ritlabs.com%2Fen%2Fnew_topic..."
I never had this kind of problems with the XP.
Any ideas how to solve this problem?
Thanks a lot for your help.
Kind regards
Kuzyn
That appeas to be a configuration error in firefox, I don't think there should be a http reference in a mail command.
Roelof Otten writes:
It should. It worked for me too in 3.99 (as i wanted to send an link via e-mail from FF). I think it is still the same unsolved issue of setting TB as default mailer and assigning to MAILTO: protocol.
Kuzyn Elmo, it does not work for me to.
With me it is exactly the same as how Kuzyn describes the problem.
I thought TB4 would solve the problem, but it did not. When I make Windows mail the default mailer, everything works allright, so it is NOT a firefox problem. And ... the mailto: links also don't work from internet explorer or acrobat reader.
Dirk van der Wulp
check solution at mozillazine:
http://kb.mozillazine.org/Windows_error_opening_Internet_shortcut_or_local_HTML_fi­le_-_Firefox
Marek,
it refers to four other extensions and not to 'mailto:' extension. As there is temporary solution (mail.reg to import to the registry) and it seems to be a problem of proper keys in the registry, I suppose it will be corrected shortly as we get new full msi version of TB!.
