Trouble configuring The Bat, Disconnects from server before mail retrieval
Having trouble with TB on my new laptop. Have everything setup the same as the previous, but when I go to retrieve my email, the process starts then disconnects.
Here is the messages from the log :
28/07/2008, 23:53:03: FETCH - connected to POP3 server
28/07/2008, 23:53:03: FETCH - authenticated (plain)
28/07/2008, 23:53:04: FETCH - 12 messages in the mailbox, 12 new
!28/07/2008, 23:53:04: FETCH - Connection to host broken (last commands sent were: "UIDL", "RETR 1")
Any help would be appreciated
Regards
Terry
PS. Using Windows Vista basic home with WLAN.
this looks more like a connection problem, does it happen if you don't use wireless connection?
Terry Le Rouge writes:
Hi, new to the forum but not to the Bat (or Voyager).
I have the same problem: Voyager on a stick, running fine for a year on my old x86 system and mu notebook. Now with my new system (x64 + xp64sp1) I get the same errors with The Bat (desktop version) and Voyager (on a U3 stick). It looks like The Bat (only) connects with 127.0.01 (localhost). OE does work without problems. The same stick inserted in my notebook also works. As you're using Vista and I XP64 maybe it has something to do with the 64bit OS.
