TheBat! and Gmail problem, Can't download messages
I've had TheBat! set up for my Gmail-account a long time now, but all of a sudden I can't download any messages from it, but I can send emails from it. Perhaps I should mention that I haven't changed any settings in TheBat! And I'm able to manually log in to my gmail-account to read messages.
I get this error when I try to connect:
"2008-10-09, 13:05:40: FETCH - receiving mail messages
2008-10-09, 13:05:40: FETCH - Initiating TLS handshake
!2008-10-09, 13:05:40: FETCH - TLS handshake failure. An existing connection was forced to close the remote host"
What can I do?
____________________
Using The Bat! v5.0.36.2
Please disregard this, as I got help from the excellent TBUDL instead. :)
Number99!
same problem.the bat suddenly cant connect anymore to gmail pop server. what was the solution from 'TBUD'?
This was sent by Mean Drake to TBUDL:
"Well I have a slightly different setup and it works fine. You could try it out. The following are the differences/highlights:
1. SMTP server port is 587
2. SMTP Connection is STARTTLS instead of TLS
3. SMTP Auth settings, pop before SMTP is unchecked.
4. POP port remains 995 with TLS connection.
5. Make sure POP auth button says regular and not one of the other 4 types.
Works fine here with these settings."
