Sending message - 5.7.0 No Auth command given
Hello,
I would like to move from Outlook to TheBat!.
The problem is that I tried every setting in the Smtp setting of TheBat!, but it keeps saying:
"Server reports error.The response is: 5.7.0 No Auth command has been given"
The Microsoft Outlook can send the message with the EXACTLY the same settings! (perform SMTP athentication, specific settings: the name and password).
Please, help me! Thank you
How did you configure it in MS Outlook?
Hello,
You can see a screenshot at http://invitel.hu/csillagzs/outlook.jpg
I erased the user name and email address, but this is not important anyway. It's in Hungarian - I can translate it if it is not clear to you.
Thank you very much.
It's been a while since I've seen this screen in MS Outlook and my Hungarian is non-existent.
Is 'Jelszó tárolása' supposed to mean 'remember password'?
But it looks rather straightforward.
Press the 'authentication' button for the send mail settings, enable 'perform smtp authentication', set 'specific settings' enter your invitel address and password. For the rest nothing should be selected.
If this doesn't work, could you enable protocol logging for smtp and post the failed session (you can disable protocol logging after one failed session) Keep in mind that the protocol log displays your password, so you'd better make that unreadable.
Thank you,
I will try it.
