setting up pop acct
I entered my info per my ISP's comcast's instructions (works with outlook), but bat keeps stating that it cannot find server. What am I doing wrong? Where can I find the specified ports? I made sure bat was allowed firewall access.
The ports are at ACCOUNT PROPERTIES / TRANSPORT and you'll see them on the right
Thanks. I did check, but it still cannot access server. My internet is working properly. It looks as if all properties are set properly. I even disconnected the virus program to see if that was the problem, so why can't it find the server. What am I doing wrong?
Doesn't bat have a help line?
try to disable the firewall completely and see if it works.
Although you allowed access, there may be another more common firewall rule that blocks it. Also disable anything else that may mess with the traffic in one or another way - antivirus apps, ad blockers etc.
