Forgive me, I'm newly, but in my sent messagge list I can't find the 'sent' date and hour. I see 'created', 'saved' but not 'sent'. What a strangeness! What can I do?
Thanks
-danny
Thanks
-danny
Thanks -danny |
That would be the date/time saved. Not all that strange really
iviarck
I see your problem. No - I was mistaken. Saved and Created are the same date. The only place the time sent is recorded is in the account log.
iviarck
Adding "Sent" as an option for a column header would be very useful.
Cheers DrT |
As a work-around, instead of sending it from your Outbox, you can open the message in the editor and press Send, it will be saved in Sent Mail with the current date/time (i.e. the time it was sent). I'm not sure how it would matter at which time you have delivered the message to your provider though. I set the 'Request Delivery Information' flag in important outgoing mail, so I get a confirmation that my message was delivered to the recipient's server, and at what time.
