Really Bizarre Column Error, Can't find any info on this one
Hello,
I have a recurring problem with The Bat -- if I try to resize the columns in the folder list manually, ie: drag them, they disappear. I can then go to view: message list columns and see that they've been set to zero pixels, and then type in a new value and get those columns back.
This is in itself sort of annoying but not the end of the world. However, I managed to cause the same problem but this time in my list of accounts/folders. Was just scrolling my mouse by and accidentally clicked at the wrong time, and now the column containing my folder names is gone. I can still see how many unread/read messages I have, but that's it.
Problem is, I can't figure out how to fix this.
Any help is appreciated!
-Christopher Buecheler
-http://www.cerebraldebris.com
Yep, that's bug I've heard mentioning before. I thought it had been fixed, but it's still present in the latest beta, so I must have remembered wrong.
The only way to fix that is the registry.
Close TB.
Start RegEdit.
Find the key:
HKEY_CURRENT_USER\Software\RIT\The Bat!\Folder Header #1
And give it an appropriate value, mine is 174 (decimal)
Start TB.
And see if it's fixed.
That did the trick. Thanks!
I'll keep checking new releases for a fix. Glad to hear it's a known bug that they're working on.
