Sending from various email accounts, inbox
Hallo
This is my first posting and am having problems setting The Bat up.
I have been using Pocomail for the last several years but it is falling behind in development and so am looking for a new program.
I have had a brief play with The Bat and am came up against its insistence of inboxes for each account. Reading through the forum I see that there is a way around it which is not very satisfactory from my view point. But if I accept that then I cannot see how you can change the account you wish to reply from. It would seem to be only from the original one which is not always the case with me. In Poco there is a drop down list of a accounts to use. Is there something similar in TB
Thanks
David
When you open a new editor, you can change the account from the bottom bar of the window. (Depending on the information and size of the window it can RARELY not appear unless you make that window full sized)
You can also change the FROM: in that field. Send out one account and have the FROM show a different account
You can change accounts using Macros in templates, the "%ACCOUNT" command. This can be done on everything from and Account, a folder, a quick tempate or even individuals in your address book.
