Copying column settings to other folders doesn't work
hello,
i just purchased the latest The Bat! Professional. everything works fine except one thing:
Copy column settings option doesn't work at all. i configured columns for my main's account Inbox and wanted to copy it to other folders and accounts. when i do Copy column settings option and tick needed folders, nothing changes - they stay as they were before.
i tried to apply column settings to one folder, to all folders, to multiple folders - the result is still the same.
how it can be fixed? i don't want to set up manually columns for dozens of folders.
Create a view mode and set that view mode for all of your folders.
thanks for the suggestion. i will try it when i get home.
Edited: Anton Belenki - 26 November 2010 14:09:56
p.s.: how i can save current modified view mode which is used in main's account Inbox, so i can use it on other folders?
Edited: Anton Belenki - 26 November 2010 14:10:32
finally, i managed to save View Modes and apply them to needed folders. it worked like a charm. thanks again, Roelof!!
now i have three View Mode templates (Inbox, Outbox and Trash) which can be applied to my numerous folders with single click. awesome!!
