I have 10000 different links like the tinyurl links below in notepad file I want The Bat to be able to send a different http://tinyurl.com/A0GBvLgs3T4kHamMZnY in each reply the bat sends I get around 3000 emails per day and I have to send out different tinyurls to my affiliate link the link killing script kils the link once its clicked so the user cant find the affiliate companys website I have a 3 reply system setup in the bat I want it to send it on the 1st reply a different tinyurl link this is for a link killing script
Download the xmp plug-in from: http://www.gaijin.at/tbpxmp.php extract it somewhere install the plug-in via options -> preferences -> plug-ins -> add -> browse to where you've extracted your download Add this line to the template where you want to add your tinyurl:
Code
%QINCLUDE(cons, 'e:\texts\urls.txt')%-
Create a template called cons via: tools-> quick templates -> create a new quick template enter these contents in your quick template:
Now on your c: drive create a directory texts In that directory you create a plain text file (with notepad) called urls.txt and you enter a whole lot of tinyurls in it , with all of them on a new line. When all tinyurls are useed, you've got to create a bunch of new ones. (add them to your file)
That's about as noob as I can explain it.
how do you get it to send it so you can say click here %QINCLUDE(cons, 'e:\texts\urls.txt')%- and the link will be hidden under the click here instead of the url
ohh i have link killing script for that i need to hide the url in the email so it says click here instead of the actual url in the bat when its sending the emails, does it use html code? because i got 3000 links in my url txt from a url shortener can i put 3000 links like this
anyways i got it to work using <a href="http://clickhere</a> so it says click here instead of the actuall address now its going to rock
i got 3000 links from 3 different cpa companies so i get paid 8 times a month and can add more cpa companies and get paid 10 or 12 times a month if i wanted too thanks bat
