Remove tags o reset, I wanted to delete my tags
hello I wanted to delete my tags or reset them someone where they save the names of the tags in which file to remove them
you can change the name to an already created tag
Thank you
From help:
Using filters you can assign tags to messages automatically. Such filters should contain the Tags -> Set Tags action. You can automatically clear tags as well.
https://www.ritlabs.com/en/support/help/68/#6619
ok thanks I need to delete them does not work I had to delete the config.cbs file but now all the labels were in capital letters and I can not change them ... I delete them and create a label again but without result I do not take the new configuration
Do reinstall, if reinstall not help then
You're need to write to the support. Open the ticket.
https://www.ritlabs.com/ru/support/
About your first question. I was try by myself and find that I can delete even native tags. See it here the image (press CTRL+SHIF+T and then preferences) -
https://content.screencast.com/users/george2534/folders/Snagit/media/915844bb-08e3-4015-a399-a536406550ac/10.21.2019-17.39.png
thanks I have tried it but they come back to contact technical support thanks
