Command Line Syntax for Run External Program with Filter
Hello,
This syntax will pop up notepad to alert us as a filter:
C:\WINDOWS\system32\notepad.exe %1
But, in the window of notepad, it shows the ENTIRE email.
Rather than the WHOLE message, we would like a filter that pops up notepad but shows only the FROM and the SUBJECT lines.
How should we write that line?
We tried:
C:\WINDOWS\system32\notepad.exe %FROM
but that created an error.
Many thanks,
G2
Use two actions. First export the message to a named file ("c:\temp\alert.txt") using a template containing:
%from
%subj
then use the Run external action as
C:\WINDOWS\system32\notepad.exe c:\temp\alert.txt
iviarck
Hi
how can I capture the whole messaga (%1) in a python script:
pyton "z:\fb send\t.py" %1
and the script is:
import sys
txt=sys.stdin.readlines()
print >> open('z:\\afsfa', 'a'),txt
Thanks.
Assign two actions to your filter, first action exports the message to a file, something like c:\test\message.txt
Second action runs external program, define the full path to the program, like c:\python\python.exe and add the proper pararameters, like the full path of the exported message.
