If I add a blank line to a template, no matter what I set the font to, the blank line will be @Arial Unicode MS 14pt
Is there a way around this? I am trying to format my reply template with a few blank lines. All the blank lines have a different font, and it is annoying me.
This happens if I use the enter key to enter a new line or if I use the %NEWLINE macro. If I highlight the entire templet and set it to (for example) Courier New 9pt, everything uses Courier New 9pt EXCEPT the blank lines!
So frustrating
Is there a cure?
So frustrating
Is there a cure?
