Where is the file containing emails and where should it go?, My laptop died today. I had to replace it in a hurry.Everything is backed up in the cloud.
What file do I need to pull off of Carbonite that contains all my emails? What folder is it in? Where does it go on the new laptop? I want to retrieve not just emails and attachments, but also the folders in which I'd been storing emails from different clients, projects, etc.
Thanks for the help!
Shel,
Presuming you accepted the default locations, use The Bat Encryption, use Windows 7 then %APPDATA%\The Bat! Pwd\
- from Start Run you can input %APPDATA%\The Bat! Pwd\ and it will open the correct location..
So c:\users\username\appdata\roaming\the bat! pwd\
Do you have a The Bat! backup file created using Tools Backup in The Bat! ?
If so simply reinstall the latest TB and when asked point to the backup file created above.
Good Luck
Cheers,
LM
Edited: Lord Melch - 05 November 2011 22:17:08
Cheers
MS
