Can be done in several ways. - You can type the alias (including address) in the From header - You can create a quick template that will enable you to set the alias by running the quick template - Set a folder identity and every time you start a message while you've selected that folder, the matching identity will be used
I use the latter. Whenever I receive a message to the an alias, the message will be moved into that folder and every time I create a message with that alias that will also be moved to the matching folder. All with the filters that TB provides.
