No sound with new incoming mail/can't set standard
Hello,
After 'being away' for a few years I re-installed The Bat. I spent some time configuring everything but I can't find the option  "Play sound when new mail arrives". Also no 'sound file' in The Bat (Program Files). Strange.
Is there still a problem with IMAP?
Thanks and regards from the Netherlands
Dutchcub
Edited: Dutch Cub - 28 February 2014 21:10:10
Check out the location of the global setting:--
http://i.imgur.com/nQR3pPN.png
cheers,
^ _ ^
Battie
Windows 8.1 Pro (64-bit) | The Bat! Pro 6.2.14 | MailWasher Pro 7.3.0 (Beta)
To set different and account-specific sounds, check out the following link:--
http://i.imgur.com/jE8TibG.png
cheers,
^ _ ^
Battie
I've updated to the current version 6.3.2 but there are no sound options available for IMAP accounts, neither on folder level nor account level.
Any idea?
http://i.imgur.com/FtyXg1R.png
Edited: Steffen Baudach - 13 April 2014 14:27:49
Both the settings (Global + Account-specific) as illustrated on my screenshots are certainly available on the 6.3.2  ;)
cheers,
^ _ ^
Battie
Windows 8.1 Update (64-bit, Pro) | The Bat! Pro 6.3.2 | MailWasher Pro 7.3.0 (Beta)
Also for IMAP accounts or only POP3?
I can see this settings only for POP3...
Those screenshots were from a POP3 account - I don't use IMAP.
cheers,
^ _ ^
Battie
Therefore i've tested this - yes, if i use a Pop3-account, the options are available, and no, the otions are absent for IMAP-accounts.
Nowadays a lot of people want to use IMAP - it should be possible to have sounds for new emails also for this ones (like other products...) ;)
Oh yes, I agree wholeheartedly with you - the sound function should certainly be available even for Users of IMAP, as well. :)
cheers,
^ _ ^
Battie
Windows 8.1 Update (64-bit, Pro) | The Bat! Pro 6.3.2 (POP3) | MailWasher Pro 7.3.0
