Actually you do and I can show you how. Just remember to keep this backed up as every full install will wipe it out
Go into the Bat's program folder" C:\Program Files (x86)\The Bat!" or whatever according to the system you have. Notice the "default.msl" Then go into the IMAGES folder and you will see the images that are there. Put some more images there and note the file names
Next open default.msl with notepad and duplicate the last line a few times then change the file names and the shortcuts to fit you needs
Smiley = ".\Default\cold.gif", 0, ":cold:"
I have removed the shortcuts and left the names because I really can't stand having
always turned into a graphic, but to each his own. Just remember to back up you work and that this will not show until you restart the Bat
you can even add BIG graphics but they will not show in the drop down real well
If you have any questions, post back here
