Emails with HTML being rendered useless?
HI AGAIN,
New to the bat.......
I am trying to open an HTML email http://i.imgur.com/DmULjiJ.png
and as you see its rendered useless... Is there a way I can set THE BAT to just show me everything? I know better to open emails from people I dont know.
Thank you,
Christopher
Chris@CWM030.com
What is missing? I see a scroll bar on the right ...
You can always open it in your browser but that inefficient way to work
What is missing?
The email does not look rendered right at all...
Look at this email from Eudora... Then look back at the one from THE BAT...
http://i.imgur.com/UbGmk4n.png
Thanks,
Christopher
chris@cwm030.com
They are rendered differently, but they seem to both be ok. Eudora's rendering looks a bit cleaner and The Bats HTML may need some drastic work done on it but every client renders HTML differently.You can load it in your browser and get a better rendering but each browser can be quite different in the way it displays
I am not sure that in this case it is a problem as much as it is a difference in rendering engines
How do you do the load in browser?
In Eudora you just right click inside the email and go to OPEN IN BROWSER........
I dont see that option in The Bat?
Thanks,
Christopher
Chris@cwm030.com
HTML rendering is pretty poor in The Bat! -- they apparently know it because there's an option that partially fixes it:
Preferences:Viewer/Editor:HTML Viewer
This has an option "Use Windows OS HTML Viewer" which disables the crappy built-in HTML rendering, and uses an external rendering engine from Internet Explorer.
The 'built-in crappy' HTML viewer protects you from multiple points of attack, lazy html and web bugs from senders. A good trade-off for most. Using IE as a HTML viewer opens your computer at all hacks that trouble IE.
Use the stripped down built-in browser for most, then if 'picture perfect' view is required, right-click open in browser (IE).
